النتائج 1 إلى 4 من 5
الموضوع: شرح طريقة تنصيب ويندوز XP بالصور How to Install Windows XP
    معدل تقييم المستوى : 679
    This procedure demonstrates how to install Windows XP Professional. The procedure to install Windows XP home edition is very similar to the professional edition. Since Windows XP Pro is more advanced operating system, it will be used to demonstrate the installation procedure.
    The best way install Windows XP is to do a clean install. It is not difficult to perform a clean installation. Before you perform the installation I recommend that you check Windows XP Compatibility List to ensure that your hardware is supported by XP. If your hardware is not on the compatibility list you can check your hardware manufactures ***site to download the drivers for Windows XP. Save all the necessary drivers onto floppy disks or CD before you start the installation.
    All versions of Windows XP CD are bootable. In order to boot from CD/DVD-ROM you need to set the boot sequence. Look for the boot sequence under your BIOS setup and make sure that the first boot device is set to CD/DVD-ROM. You can then perform the following steps to install Windows XP:
    Step 1 - Start your PC and place your Windows XP CD in your CD/DVD-ROM drive. Your PC should automatically detect the CD and you will get a message saying "Press any key to boot from CD". Soon as computer starts booting from the CD your will get the following screen:
    Step 2 - At this stage it will ask you to press F6 if you want to install a third party Raid or SCSI driver. If you are using a an IDE Hard Drive then you do not need to press F6. If you are using a SCSI or SATA Hard drive then you must press F6 otherwise Windows will not detect your Hard Drive during the installation. Please make sure you have the Raid drivers on a floppy disk. Normally the drivers are supplied on a CD which you can copy to a floppy disk ready to be installed. If you are not sure how to do this then please read your motherboard manuals for more information.
    Step 3 - Press S to Specify that you want to install additional device.
    Step 4 - You will be asked to insert the floppy disk with the Raid or SCSI drivers. Press enter after you have inserted the disk.
    Step 5 - You will see a list of Raid drivers for your HDD. Select the correct driver for your device and press enter.
    Step 6 - You will then get a Windows XP Professional Setup screen. You have the option to do a new Windows install, Repair previous install or quit. Since we are doing a new install we just press Enter to continue.
    Next - How to install Windows XP (Part 2)
    Step 7 - You will be presented with the End User Licensing Agreement. Press F8 to accept and continue
    Step 8 - This step is very important. Here we will create the partition where Windows will be installed. If you have a brand new unformatted drive you will get a screen similar to below. In our case the drive size is 8190MB. We can choose to install Windows in this drive without creating a partition, hence use the entire size of the drive. If you wish to do this you can just press enter and Windows will automatically partition and format the drive as one large drive.
    However for this demonstration I will create two partition. The first partition will be 6000MB (C: drive) and second partition would be 2180MB (E: drive). By creating two partition we can have one which stores Windows and Applications and the other which stores our data. So in the future if anything goes wrong with our Windows install such as virus or spyware we can re-install Windows on C: drive and our data on E: drive will not be touched. Please note you can choose whatever size partition your like. For example if you have 500GB hard drive you can have two partition of 250GB each.
    Press C to create a partition.
    Step 8 - Windows will show the total size of the hard drive and ask you how much you want to allocate for the partition you are about to create. I will choose 6000MB. You will then get the screen below. Notice it shows C: Partition 1 followed by the size 6000 MB. This indicates the partition has been created. We still have an unpartitioned space of 2189MB. Next highlight the unpartitioned space by pressing down the arrow key. Then press C to create another partition. You will see the total space available for the new partition. Just choose all the space left over, in our case 2180MB.
    Step 9 - Now you will see both partition listed. Partition 1 (C: Drive) 6000MB and Partition 2 (E: Drive) 2180MB. You will also have 8MB of unpartitioned space. Don't worry about that. Just leave it how its is. Windows normally has some unpartitioned space. You might wonder what happened to D: drive. Windows has automatically allocated D: drive to CD/DVD-ROM.
    Select Partition 1 (C: Drive) and press Enter.
    Step 10 - Choose format the partition using NTFS file system.This is the recommended file system. If the hard drive has been formatted before then you can choose quick NTFS format. We chose NTFS because it offers many security features, supports larger drive size, and bigger size files.
    Windows will now start formatting drive C: and start copying setup files as shown on the two images below :
    Step 11 - After the setup has completed copying the files the computer will restart. Leave the XP CD in the drive but this time DO NOT press any key when the message "Press any key to boot from CD" is displayed. In few seconds setup will continue. Windows XP Setup wizard will guide you through the setup process of gathering information about your computer.
    Step 12 - Choose your region and language.
    Step 13 - Type in your name and organization.
    Step 14. Enter your product key.
    Step 15 - Name the computer, and enter an Administrator password. Don't forget to write down your Administrator password.
    Step 16 - Enter the correct date, time and choose your time zone.
    Step 17 - For the network setting choose typical and press next.
    Step 18 - Choose workgroup or domain name. If you are not a member of a domain then leave the default settings and press next. Windows will restart again and adjust the display.
    Step 19 - Finally Windows will start and present you with a Welcome screen. Click next to continue.
    Step 20 - Choose 'help protect my PC by turning on automatic updates now' and press next.
    Step 21 - Will this computer connect to the internet directly, or through a network? If you are connected to a router or LAN then choose: 'Yes, this computer will connect through a local area network or home network'. If you have dial up modem choose: 'No, this computer will connect directly to the internet'. Then click Next.
    Step 22 - Ready to activate Windows? Choose yes if you wish to active Windows over the internet now. Choose no if you want to activate Windows at a later stage.
    Step 23 - Add users that will sign on to this computer and click next.
    Step 24 - You will get a Thank you screen to confirm setup is complete. Click finish.
    Step 25. Log in, to your PC for the first time.
    Step 26 - You now need to check the device manager to confirm that all the drivers has been loaded or if there are any conflicts. From the start menu select Start -> Settings -> Control Panel. Click on the System icon and then from the System Properties window select the Hardware tab, then click on Device Manager.
    If there are any yellow exclamation mark "!" next to any of the listed device, it means that no drivers or incorrect drivers has been loaded for that device. In our case we have a Video Controller (VGA card) which has no drivers installed.
    Your hardware should come with manufacturer supplied drivers. You need to install these drivers using the automatic setup program provided by the manufacturer or you need to manually install these drivers. If you do not have the drivers, check the manufacturers ***site to download them.
    To install a driver manually use the following procedure:
    (a) From the device manager double click on the device containing the exclamation mark.
    (b) This would open a device properties window.
    (c) Click on the Driver tab.
    (d) Click Update Driver button. The Wizard for updating device driver pops up as shown below:
    You now get two options. The first option provides an automatic search for the required driver. The second option allows you to specify the location of the driver. If you don't know the location of the driver choose the automatic search which would find the required driver from the manufacturer supplied CD or Floppy disk. Windows would install the required driver and may ask you to restart the system for the changes to take affect. Use this procedure to install drivers for all the devices that contain an exclamation mark. Windows is completely setup when there are no more exclamation marks in the device manager.
    1. شرح طريقة تنصيب ويندوز 7 بالصور how to install windows 7
      بواسطة En.Khaled Alfaiomi في المنتدى ملتقى دروس الكمبيوتر ونصائح الإستخدام شروحات مصورة Computer lessons
      آخر مشاركة: 05-02-2010, 08:29 AM
    2. Sony to disable another original PS3 feature: "Install Other OS" (The Gadget Hou
      بواسطة Mgtrben news في المنتدى Tech News World 24/24
      آخر مشاركة: 04-02-2010, 04:02 AM
    3. Sony Zaps PlayStation 3 'Install Other OS' Feature (PC World)
      آخر مشاركة: 03-29-2010, 08:40 PM
    4. إجماع خليجي على تنصيب سلطان بن فهد رئيساً للاتحاد العربي
      بواسطة Mgtrben Sport في المنتدى الملتقى الرياضي وكرة القدم Football & Sports Forum
      آخر مشاركة: 03-22-2010, 07:23 PM
