In The name of Alla
First: Fruit and the memory
Fruit has a very positive effect on the brains just like carrots. So if you want to stimulate your brain functions you have to eat much fresh fruit and carrots (raw).
One of the substances that fruit contains are natural sugars. They stimulate the brain so we can think faster and recall information more quickly. There are many other substances that fruit contains which scientists think they stimulate the brain. How this works and which substance is responsible for which effect is still unknown as of yet and research is done at this very moment.
Students: improve your exam results!
We would like to tell you more about how students can improve their results by changing their eating habits before they have an exam. Fruit is the ultimate brain fuel!
You can actually improve your test results simply by changing your eating habits between waking up and doing the exam. The big trick is to consume fruit effectively. Have only fruit but as much as you want before you do your test and avoid the brain blocking foods white flour, refined white sugar, meat and dairy.
Check it out yourself once and you'll notice that you can think much more clear and faster if you have only eaten the right and light stuff before the exam. Afterwards you can have whatever you want!
Fruit
The effect fruit has on your brain is that it makes you think faster and recall information more easily. This is only an example. There is much more to learn about nutrition. There is also nutrition that has a negative effect on your brains.
Brain blockers
Here is a list of things that have a negative effect on the functioning of the brains:
* White flour, especially in combination with cheese. This forms a sticky substance in the intestines that costs much energy to digest. Much blood has to be sent to the digestive system so it cannot be sent to your head;
* Refined white sugar;
* Turkey; it contains a toxic element that has a strong tiring effect, it makes you sleepy;
* The combination of proteins (meat) and starch (potatoes). These two foods are burnt in a different way. It will cost your body more energy to burn them together than apart from each other.
Inform yourself
Not only fruit stimulates your brains, another type of food that does is carrots. Eat some raw carrots at least once a week to stimulate your memory.
Please any body don't understand , use the dictionary
ترجمة الموضوع
ترجمة للموضوع
بسم الله
أولا : الفاكهة والذاكرة .
الفاكهة لها تاثير إيجابي للغاية على العقول تماما مثل الجزر . حتى إذا كنت ترغب في تنشيط وظائف الدماغ الخاصة بك فعليك أكل الكثير من الفواكه الطازجة والجزر ( الخام ) .
واحدة من المواد التي تحتوي هلى سكريات الفواكه الطبيعية . فإنها تحفز الدماغ بحيث يمكن أن نفكر بشكل أسرع , ونتذكر المعلومات بسرعة أكبر .
هناك العديد من المواد الأخرى التي تحتوي على الفاكهة والتي يعتقد العلماء انها تحفز الدماغ .
فكيف يعمل هذا المضمون ويكون مسؤولا عن هذا التأثير الذي لا يزال مجهولا حتى الآن ويتم البحث في هذه اللحظة بالذات .
الطلبة : تحسين نتائج الإمتحان !
نود أن نقول لكم المزيد عن كيف يمكن للطلاب تحسين نتائجهم من خلال تغيير عادات الأكل قبل الإمتحان .
فالفاكهة في نهاية المطاف هي وقود للدماغ .
يمكنك فعلا تحسين نتائج الإختبار ببساطة عن طريق تغيير العادات الغذائية بين الإستيقاظ والقيام في الإمتحان .
الخدعة الكبرى هي استهلاك الفاكهة على نحو فعال .
ولكن بقدر ما تريد قبل أن تبذلو اختبار المخ وتجنب عرقلة الأطعمة , البيض , والدقيق والسكر الأبيض المكرر واللحوم والألبان .
تحقق من ذلك بنفسك مرة واحدة وستلاحظ أنه يمكن ان يخطر لك أكثر من ذلك بكثير واضح وبشكل أسرع اذا كان لديك فقط الأكل السليم والخفيف قبل الإمتحان , بعد ذلك يمكنك الحصول على كل ما تريد .
الفاكهة :
أثر الفاكهة على دماغك هو أنه يجعلك تفكر أسرع وتتذكر المعلومات بسهولة أكبر . هذا ليس سوى مثال على ذلك .
هناك أكثر من ذلك بكثير لمعرفة المزيد عن التغذية .
وهناك أيضا تغذية يكون لها أثر سلبي على عقلك .
حاجزو اللدماغ :
هنا لائحة من الأمور التي يكون لها تأثير سلبي على سير العمل في العقول .
* الطحين الأبيض , وخصوصا في تركيبته مع الجبن . وهذا يشكل مادة لزحة في الأمعاء فتتكلف الكثير في طاقة الهضم .ودماء كثيرة ترسل الى الجهاز الهضمي لذلك لا يمكن ان ترسل الى راسك .
*السكر الأبيض المكرر .
* لحم الديك الرومي : إنه يحتوي على عناصر سامة لديها تأثير قوي متعبة , يجعلك نعسان .
* مزيج من البروتينات ( اللحوم ) والنشا ( البطاطس ) .هذه الأطعمة تحرق بطريقة مختلفة . سيكلف جسمك على حرق المزيد من الطاقة .
أبلغ نفسك :
ليس فقط الثمر يحفز عقلك , نوع آخر من المواد الغذائية وهي الجزر .أكل بعض الجزر الخام على الاقل مرة في الأسبوع لتنشيط الذاكرة الخاصة بك .
info@mgtrben.com
